Discuss aquapanel onto floorboards in the UK Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
P
pr1970
Hi All
I`m about to tile my bathroom floor, the floorboards are in pretty good nick and flat apart from a couple of small 1inch gaps near the edge. I was originally going to put down some 6mm plywood and then aquapanel but I`m thinking is it ok just to put the aquapanel straight down onto the floorboards with a bed of adhesive and then screwed down.
thanks
Paul
wetdec
Why aqua panel you could simply 6mm ply it whats going on top, we'r talking 6x1 boards ye ?
H
Holohana
I suggest using 6mm Hardiebacker boards. They are water resistant. Simply fix onto a thin bed of ashesive to fill any voids through uneven floorboards and screw every 200 centres.
No need to prime either!
P
pr1970
Decided on aquapanel just to be safe in case of any water leaking through.
I`ve bought it now so too late to go back to the plasterboard idea.
These are the panels I bought
Wickes  – Building Materials – Plasterboard – Plasterboard – Aquapanel Insulated Backing Board
thanks
Paul
grumpygrouter
These are insulating boards designed for insulating under floor heating. Are you trying to add strength to the floor or just give a good surface to tile onto?
wetdec
DS Tiling
If the aquapanel was going into a wet room then a waterproof membrane should be installed but for a normal bathroom floor I can't see any requirement. The aquapanel will be fine if screwed onto an adhesive bed, not so sure about the aquapanel thermal though if that is what you have purchased.
P
pr1970
Hi
Thanks, yeah think i`ve made a mistake getting the thermal type. I`ll get that changed. Its also not for a wet room, just a standard bath which wont have a shower, just an attachment. Although there wont be a screen so I expect water on the floor occasionally.
So would either hardibacker 6mm screwed down to the floorboards be ok, or does it need a adhesive down too? btw i`m using ceramic tiles on top.
cheers for the advice
Paul
grumpygrouter
Hi
Paul
If ti is just to put a "nice" surface down to tile onto, then 6mm hardie is fine, you will need to lay it onto adhesive first and then screw down. Check the hardie site for install instructions, they should be on there.
if you are after strenghtening the floor then you need to be looking at a min of 15mm ply, usually 18mm as 15mm does not seem to be available here.
GazTech
Andy, can you confirm which type of adhesive is suitable to bed the boards, and which to fix tiles with when using 6mm boards fixed down in this method ....Gaz
P
pr1970
Thanks for that.
Can i just check , should I put down some 6mm ply first then the hardibacker or could I put the hardibacker straight down onto the existing floorboards (with screws & adhesive).
Would prefer not to use ply as that add to the height of the floor.
Cheers
Paul
DHTiling
Hi paul...
Make sure the floorboards are well fixed and secure then use a flexi adhesive to put a base for the hardie board then fix with screws......
Reply to aquapanel onto floorboards in the UK Tiling Forum area at TilersForums.com
Apatel
