Your thoughts on splitting Silicon...
I came across this a while back and in some rare cases sanitryware need to be primed prior to sseling with a sealant.
The experience I had required the sanitryware to be sealed with Mapei's Primer fd before resealing the area with mapisil ac
I think some types of resins in certain baths and trays can be problematic in terms of getting a good bond.
To the best of my knowledge the primer fd is rather rare and had to be ordered from Italy or Poland.
hope this helps
hi rich this happened to me using mapei Silicon
check the sell by date as this was the issue with us
the siliconed curled up on tile and opposite surface and came away from the surface
out of date Silicon was the issue
Thank you all for your help. The walls are plaster, the bath and tray have not been cleaned with anything and the Silicon is in date. I went back last night, removed the ultra Silicon and replaced with Mapei but Im not convinced that it will hold. It seems to me that tfs and Mosaic girl are on the right tracks, I had thought about a primer but on the tube of Silicon they say that you need to prime with the FD on porous surfaces. Now I have used Mapei, I will be on the phone to them to see what the best plan of attack is. Thank you again all, I will keep you informed.
GO TF!! :thumbsup:
'Release agent' that was the term I was looking for - the release agents for Silicon are not just washing up liquids are they, they are petrol based things like vaseline, oil, petrol, ... and it could well be in those plastics... yes, keep us posted, Rich.. 🙂
Re: Your thoughts on spliting Silicon...
Hi Rich, was is a stone tile as Silicon doesnt stick to alot of stone tiles very well ?
Was the protective surface liner fully removed across the full width of the ledge so as not to act as a Silicon bond-breaker between the Silicon and adjacent ledge that may cause de-bonding after cure shrinkage has occured?
Its the protective coating on the white goods that are causing the problem,there will be some sort of oily residue on it ,little bit of thinners or the like should remove it.
Thats why i never ,ever get involved in siliconing thats the plumbers job when he does his final fix lol
I have seen cases where installers use white spirits to clean ledges in preparation for Silicon.
White spirits is oil based. You can imagine the consequences!
No the tiles are ceramics, as said above thinners is not much cop to clean down with as it can leave a residue. The areas were cleaned down with meths before the first lot of Silicon was done (as this shouldn't leave any residue). The protective coating was removed.
Have had a look at the Mapei FD primer... :yikes: Wow!! that is expensive!
Rich,
SJPurdy,
Rich,
SJPurdy,
