I'm Looking For This Tile White And Black Johnson Tiles
TonyMorgan
Hello everyone, looking for some help from you guys. Can anyone tell me the name of the tiles in the photos? They are 190x190x4mm I think. Not even sure how to describe the type of tile! They are Johnson and have the numbers 88 06 and 88 04 on the reverse. Your help would be much appreciated, thanks,
Tony
These are the Switch tiles. White = SWT12A discontinued 2006, Black = SWT13A discontinued in March 2010 and the factory have no stock left or either
They are 197x197x6.5. The only option I can see is to go for their Prismatics Satin White (PRS12) and Satin Black (PRS13). These will be the same size and colour but completely flat. The finish will be almost identical but due to the length of time passed could be slightly more on the matt side in comparison.
Thanks Paul, you have saved me alot of effort. I will use the replacement tiles as they will be relatively well hidden.
Thanks again,
Tony
Thanks again,
Tony
Hi i no where to get these tiles definitely the white ones not sure on the black if still needed
Can you measure the exact size off the tile. i no the other guy said its 197x197 which is just shy off 8" as I think the one we have is 150x150 6" but I will double check Monday morning.
Joe
Hi Tony
Just checked and the one we have is the same size but slightly different pattern I've attached a picture.
TonyMorgan,
TonyMorgan,
TonyMorgan,
TonyMorgan,
