Discuss Which drills for porcelain tiles ? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
shiftspark
Hi forum !
I have just had my bathroom tiled in porcelain tiles and need advice on which drills to use for fitting the shower screen , toilet and basin etc I am not sure which size yet but would assume around 6-7mm
I have seen the erbauer ones on screwfix but they look tricky to start the hole with out wandering, would I be better with the arrow type if so which can you recommend?
Thanks in advance !
Colin
Q
Qwerty
Have a browse on our forum sponsor website- @Pro Tiler Tools . They will have what you need.
Hole Cutting | Amazing Prices for Tile Cutters to Buy Online | Pro Tiler Tools - https://www.*******************/categories/tile-cutters/hole-cutting
Dumbo
Don't drill a 7mm hole for a 7mm plug unless you push the plug through the tile . Because if you leave the plug in the tile when you put the screw in it can expand and crack the tile
Tommcd
The erbauer ones aren't that tricky, you just have to start at an angle and slowly straighten up. Try to hold the barrel of the drill with your left hand and lean you're left forearm on the wall so the drill doesn't slip. I usually have a little tub of water nearby and cool the drill bit down every 20 seconds or so. Needs to be high speed so don't bother with a cordless drill!
Get a small piece of sheet material like 4-6mm mdf or ply, bore a hole with your chosen bit in to that.
Place the hole where it needs to be over the tile and it will hold it rock steady.
If you can get a second person to hold the board, then you can concentrate on using the drill, and if you’re feeling amphibious, hold a damp sponge against the drill bit to keep the bit and tile cold.
It will give a faster cleaner cut with no risk of the porcelain overheating and reducing the risks of cracks and chips. :):thumbsup:
WetSaw
On the subject of drilling...
I arrived at a job I'm doing to find the owner helpfully drilling ( well, trying to drill ) holes in the tiles to fit a towel rail. He was using one of those arrow type bits on porcelain tiles. Not only had he only just got through the glaze, he was drilling in the wrong place! A few minutes with a Rubi wax filled bit on the angle grinder and all 4 holes were done, in the correct position. Luckily the fitting covered his mistake!
I
Italy
plumbers, blacksmiths, furniture assembly, are a plague
for our work performed.
at least here in Italy ....
few know how to use a diamond bits and many do not know that they exist.
shiftspark
Just a quick update, I used a 6mm Marcrist bit ,started it at a 45' and slowly stood it up.
Thanks for the advice.
Reply to Which drills for porcelain tiles ? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
laattaana
