Discuss which adhesive to use on t and g floor? in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
hi guys im confused after searching ages looking at adhesives and grouts for my project, im tiling on a tongue and groove floor lined with 6mm ply and primed .
does this stuff fit the bill for porcelain floor tiles on wood and do i also need a flexible grout to finish ?
thanks
dave ..
Tony_C
The adhesive will be fine but you may be better off with a slower setting bagged adhesive.
Ditto on the 6mm ply, use a backer board instead
Ok I have ordered 6mm backer board and the stainless fixing washers and screws ,do I also need to use adhesive on the boards to fix them and should the joints be taped ? If so which tape and adhesive should I use please ??.
Thanks again.
Reply to which adhesive to use on t and g floor? in the Canada area at TilersForums.com
laattaana
