Warmup UFH 1.8mm cable - does it need levelling compound?
V
vala
Hi all,
I'm in the process of getting all set up for a first floor refurbishment on my property which includes the installation of electric underfloor heating in wetroom.
I've come across a loose wire system from Warmup and it mentions the wire is 1.8mm thick and you can apply tile adhesive straight on top, removing the need for a self levelling compound.
I've read a number of threads on here which mention applying a self levelling compound but haven't come across one yet which doesn't.
Has anyone ever used this product and not used a self levelling compound before the tile adhesive?
To be honest, applying the SLC doesn't add to the height really. And it encases the cables and stops you snagging them when you trowel over it with adhesive. So for peace of mind, it's always wise.
You need to make sure your stat is outside the wetoom and that you're using the floor probe only, not room sensor (as the sensor wont be in the room).
What floor surface (substrate) are you tiling to? Is it wood or concrete or something else?
Dan - I thought/read that you should really add ~10mm on top of the thickness of the cable (in this case 2mm)?
Yes, plan is for the stat to be in the landing area, which is on the other side of the partition wall to the wetroom. This area, along with the bedrooms will also have underfloor heating.
It's on the first floor and is a wooden substrate. I'll be ripping up the floor I expose the joists on to which I'll first reboard with ply, then apply a tile backer board for which the UFH then tiles will go on to.
In the other areas I'll use insulation boards before fitting the UFH then engineered wood flooring.
Ray - I'll take a look into that product you mention.
ive laid every electric ufh system there is and the schluter really impressed me and that takes some doing believe me. there website has a calculator to help u get the exact system required
Warmup's fine. Don't worry about it.
You're only encasing the cable so you don't trowel over / through it during troweling adhesive. And to ensure it doesn't rise, like it might in wet adhesive. It's quite a skilled job to tile over cable and not damage it. And trust me, you use more adhesive than usual.
How much room have you got to play with?
Dan - apologies for the delay in getting back to you. Been busy with work.
The area of the bathroom is 2.2m2.
I don't bother latexing small floors just tile over them. I use bal single part fast flex and bal wide joint grout with gt1 admix.
I use a plastic trowel designed for tiling over the wire to help prevent damage remember to back butter the tiles...I've done loads of small bathroom floors this way and never had a problem.
Like Andy, I've done lots of small floors this way, as long as ur diligent it will be fine.
The only thing I'd add is that remember to make sure u encase all the cabling in adhesive.
Exposed to air pockets, the cable can overheat, I believe.
vala,
vala,
vala,
vala,
