Discuss Using raimondi on ditra matt in the Canada Tile Advice area at TilersForums.com.
G
GoneGuy
hi all
Just a general question.
Is it posssible to use a tile level system such as raimondi etc on top of a decoupling membrane?
G
GoneGuy
If the whole floor was covered with decoupling membrane and only half tiled the room, would it be more difficult to use level system next day as the adhesive would have hardened and might pull/separate the membrane?
Simons70
IMG_1120.JPG You can fix all before you leave and you heave it ready next day.See the last row in picture
G
GoneGuy
Did you leave the clips in or did you just leave a gap then put clips in when you started next day
Reply to Using raimondi on ditra matt in the Canada Tile Advice area at TilersForums.com
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
Hi, hoping for some advice.... Had a anhydrite screed laid early Feb. Looking at laying 20mm...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Hello, Hopefully someone can advise as I'm confused when it comes to choosing correct adhesive...
Hello guys, I'm doing a wetroom and will be using Ditra Heat Duo membrane for the UFH. I looked...
Bob Marley
