Trim - After Tiling
L
Lebowski25
Hi all
This is my first post so go easy on me.
I've just finished tiling my bathroom.
Ehere the tiles end I have put grouting, however it looks very amateur as it is bumpy and doesn't look great.
I want to cover it with a trim, as I didn't think of it at the time of tiling.
Can anyone recommend any trim for after tiling? i pursvhased some from B&Q, however I'm finding it hard to stick to both tile and wall.
(There seems to be a gap)
Is it worth adding tile adhesive under the plastic trim?
If anyone has added a trim after tiling, could you give me some advice please.
Thankyou
Hello and welcome to the forums........
It will be tricky to get a good finish once the tiles are on , with tile trim....you can cut the flat side of the trim off and stick the remainder on but this might not last.....you will have to remove a row of tiles to get it to tuck down the back...
let us know which way you go.
It will be tricky to get a good finish once the tiles are on , with tile trim....you can cut the flat side of the trim off and stick the remainder on.
When cutting the flat side off tile trim, what what you are doing with the blade :lol:
Welcome to the forums :thumbsup:
I wonder if it is that 'bath trim' you get which (the diy shops tell you) that you can stick either on or under the tile?
Trim - After Tiling
Lebowski25,
Varley,
Lebowski25,
Varley,
