Tiling over a wooden floor
Joana
Hi guys, I am new to this forum .Me and my partner Ian are renovating a property currently and have some questions about tiling as we are trying to do this between us. The make up of the floor is as follows : dpm / cement / 40-50 cm gap (not much crawling space at the solumn of the house!) / floor joist at about 50 cm centers / treated wooden floors all over the house , 2 cm thick, t&g. We have used hardie backing board of 6 mm directly on the wooden floors. Ian used torque screws. I was hoping that the backing board and screws will stiffen the structure of the floor but no such luck. I can see the floors moving/bending slightly when Ian walks over the hardie board. Should I use ultra or extra flexible tile adhesive in this case ? What would you recommend for such a floor ? I would not like to take a chance, go ahead and tile, and find later that I've used the wrong product. Thanks . Joana
You needed to secure the floor joists to the concrete base so that they do not bounce when walked on.
One support every metre along the joists would have helped.
No , just torque screws, every 3 inches or so I believe Ian places them. Quite a few screws on one board. Is that enough ? I must admit this is something totally new to us. I've tiled before but on concrete direct.
The floor joists are running through the house but they are partly independent from the concrete they run through the brick walls 50 cm above the concrete. Here and there the joists are supported by a small brick wall , non load bearing , rising from concrete to just under the wooden floors. Of course I punctured some of these small walls only between the joists to create passages for crawling in below, for insulation, Plummer work and future inspections.
How much adhesive would a hardie backing board use before glued on the wooden floor ? 2 mm or so ? And should I glue directly on the wooden floors the hardie board ? Wait to dry and tile directly on that.
Yes, but if the joists are bouncing when walked on then you should have supported them better. Another way is to add thicker layers ontop of the T&G flooring but that could still be a problem.
The tile adhesive does not resolve the problem of deflection, it only fills voids under the Hardie and between the T&G flooring.
Can you still get under your floor?
If so, go and add some more supports between the bottom of the joist and the concrete base, this will stop the deflection.
Joana,
Dumbo,
Joana,
Dumbo,
