Tiling outdoors advice
Balloo
Guys any advice on material and preparation for tiling 50mt patio .
As you all know frost and the usual British isles weather can create major problems with porcelain.
Has anyone used bal rapid mat for decoupling, I've a load ofit left over from previous job is it any good for outdoors , or even needed
Try Dural
Or stick with proper drainage solutions which will make sure your tiling lasts more than 12 months.
Expensive you say?! Try the expense of re-doing it all after scrimping on a drainage layer...
Here's one done just over 12 months ago...
Think you might need to look a bit further than the Ci mat Mark...you'll be surprised at what you might find
I watched a video on YouTube for the installation of ditra drain and they didn't waterproof the balcony before putting ditra drain down is it's a necessary and if so would an ordinary tanking kit work
Why would you want to waterproof .
The ditra drain is designed for water under the tiles to run away .
Balloo,
Balloo,
Balloo,
Balloo,
