Tiling onto uneven floor
miksto
I've used some latex self-levelling compound to even out a concrete floor prior to tiling. Unfortunately the surface hasn't ended up as flat as I was hoping, with ridges left in some places where the flow ended. I had to pour the self-levelling compound from two different corners of the room (because of a slight hump in the middle of the room plus a rise in the third corner) and was unable to get things to marry up cleanly in the middle. The result is somewhat disappointing, I have to say.
I've laid some tiles out without adhesive just to see how flush they fit to floor. Alas, in many cases there is a bit of wobble present rather than even contact across the whole surface area of the tile. Can I deal with this by varying the thickness of the tile adhesive or do I need to get the floor 100% flat before tiling, perhaps by pouring another coat of SLC?
I'm reluctant to do the latter, in case I end up with same problem as before and because the stuff is expensive. I’m tempted to see what I can do with the tile adhesive - if the worst comes to the worst and I end up with one or two cracked tiles I can always replace them - they're only cheap ones and I have quite a few spares, and it's my own property and I'm not moving out in a hurry. How quickly would a failure in a particular part of the tiling become evident and how easy is to replace a cracked tile should this happen?
Any suggestions would be much appreciated.
Thanks,
Mike
Self level again Mike.This time using the plastic packers used when fitting windows.There will be all differant thickness's 2mm,3mm,5mm,10mm etc.Find the highest point of the floor and with a long level work out where the dips are and put the correct packer under the level to get the same height to the highest point.
I put the packer on a blob of Silicon to stop it floating when the slc goes down.
If a large floor say 30sm divide maybe into 3 and do 10sm at a time.Pour the slc and work it to the height of the packers.
Always have acheived a good result on very uneven floors this way.
Do check the thickness you can go with the slc
you could use a ptb adhesive (pourable thick bed)
I'm not sure if you are a DIY'er or Pro, but my experience of PTB is that it is not for the DIY'er.
I would have thought that another go with slc to take out the low spots would be your best course of action.
miksto,
miksto,
miksto,
miksto,
