Discuss Tiling Onto Timber Floor With 4 Inch Joists in the Australia Tiling Forum area at TilersForums.com.
mattle40
im sure you know already but didn't want to assume, you will still need a movement joint in the tiles.
Unless permat is capable of bridging sufficiently? But I'm sure Ray will clear that up.
Apparently it can but I'm always dubious of such witchcraft.
R
Rizzle from the Portizzle
well heres a couple of pictures of a test i put it throught you will have to make up your own minds how much movement you think you will have
R
PS if you line your grout join up with the two floors this will give you even more movement scope
Reply to Tiling Onto Timber Floor With 4 Inch Joists in the Australia Tiling Forum area at TilersForums.com
