Discuss Tiling onto ply over water ufh in the Australia Tiling Forum area at TilersForums.com.
On one
It's a self build and the ufh is a new system apparently.
I will try get a photo tomorrow.
I know 9mm ply is no good normally but it's glued and screwed already :-/
And edges fully supported with noggins?
I walked away from a similar (self renovation) job that was boarded straight onto the joists with 18mm WBP,but with no noggins under the edges. Large format marble to boot as well.
stusgsx
The floor itself is really solid I'm just worried about going onto ply when it's going to be expanding with best etc. I'm thinking ditra matting at least
Found a section that is visible to show the ufh. You've got 22mm green chipboard, 15mm mdf with pipe inserts sunk in then 9mm ply glued and screwed
Reply to Tiling onto ply over water ufh in the Australia Tiling Forum area at TilersForums.com
