Tiling onto Plasterboard in Shower
Prime, tank and tile, leave movement joint around the shower tray and Silicon it using sanitary grade Silicon. Wallop some Silicon around the shower unit too, if its an electric one.
Single part flexible adhesive and flexible grout.
J-D
I'm with Gaz all the way on the adhesives for this job!! BAL White Star all the way mate!! I'd offer them the BAL/Weber tanking solution as well to guarantee it all staying water-tight!!
If you are going to tank, tub adhesive possibly is not the way to go!
Grumpy
would'nt tile a shower without shower tray fitted
tray might not fit arfter
nnn some trays hava small lip around the edge of em that the tiles gotta cover
be hard to get a good seal if fitted after...
some mosaic's can be thicker or thiner than yeah main tile,might be worth checking n pionting out to customer if so
n do the mosaic joints have to line up with the main tile...some can some cant
green plaster board fine for domestic showers ...green ones moister resistant..fine with tube stuff..... (not blue star though) defo
:ninja:
Some of the threads in the tiling forum that have had a lot of views are being bumped up into current discussion. Just walk on by if it's not your flavour right now. Perhaps it'll help somebody out one day, and they become members, and then they post a thread, and professional tilers respond, and then you learn something from them...? Maybe?
rustylt2,
Dan,
rustylt2,
Dan,
