Currently reading:
Tiling on to painted wall
Discuss Tiling on to painted wall in the Canada Tile Advice area at TilersForums.com.
Chris Gibbs
608
North wales
do I understand you want to tile on a painted wall? if so, remove the paint. couple of ways to do this.
1, sand downs with a sander, use a course grit... I've done this its fairly quick, but use dust extraction cos it can get messy.
2, spread a thin layer of tubbed tile adhesive on the area you want to tile, wait 15 minutes and scrape it off. when you do this you realise why you shouldn't tile over paint.
Then prime with a primer. I use tilemaster primeplus 3 to 1
hope this helps.
Reply to Tiling on to painted wall in the Canada Tile Advice area at TilersForums.com
Hello, I am a noob trying to tile our shower. Since the old tiles were taken off, some of that wall material has been taken off as well, so everything had to be smoothed. After smoothing with some...
I have moved into a new house and want to tile the downstairs bathroom walls. Its not a big room but my wife likes the idea of a feature wall tile and then a grey / white tile on the other 3...
Hi all, I'm hoping you can help with some feedback, please My parents are currently having a new bathroom installed, all stripped back to bare walls and floor. The fitter has done/hasn't done...
Hello, after tiling the kitchen area I did grouting but I am not happy with the results. The grout lines are too bright, almost white. Although I used almost dry sponge to wipe off the excess...
