Discuss Tiling On Floorboards in the Canada Tile Advice area at TilersForums.com.
mbc0
Thanks so much for all the replies! is there any advantage to cement boards over hardi boards other than what I can work out it better adhesion to concrete boards?
Blunt Tool
Hardi board is cement board, Hardi just a make
NWTiles
33
blackpool
2 coats acrylic primer cross coat between application to ensure full coverage.
A decoupling Matt would be fine to use, Ive mentioned fast flex earlier, when used with a 3mm solid bed fixing trowel becomes a decoupling system as it contains a rubber instead of a sand, as you’ll have solid bed which then acts as the fracture mat.
Costs of bal fast flex £45 covers 6m2
Cost of ditra I get it by the roll for around £7m2 then use trade flex s1 at £15 a bag covers 5m2
So both are around the same price. But you save time with the fast flex, it’s vital you use the 3mm solid bed trowel to ensure the full spread underneath the tiles to create the matt.
Reply to Tiling On Floorboards in the Canada Tile Advice area at TilersForums.com
