Tiling Around Door Frame
DazJWood
I am in the process of tiling my bathroom with travertine.
My door frame is flush with the cement board walls and I am wondering the best options with regardings to tiling this area. If I remember there was skirting or arcatrave (whatever it's called) around this area prior to me ripping the old plasterboard walls out.
Is it the usual practise to put this arcatrave back up and then tile upto it?
I was wondering what other options there maybe as I quite like the idea of not having the wooden surround back on the frame. I like the idea of just having the tiles. If I did this though do I tile upto the frame, which would mean the tiles would stand proud and then the frame wouldn't be flush. If I tile over the frame to take the tiles flush with the inside of the frame then I am guessing I could potentially then have the door clashing with the tiles on closure.
I'd appreciate any advice anyone can give on their experiences or chosen methods.
Thanks,
Daz
yep Daz, put the architrave back on and tile up to it, leaving a 2-3mm gap right round for a silion bead after grouting. Don't grout this gap as it will only crack out and will counteract the benefits of using silicon.
Thanks for the response.
Can it be done without the architrave or would it look odd?
My tiles are thick travertine tiles around 12mm thick. This plus around 3mm adhesive means it would be 15mm thick off the wall. The architrave that was removed is probably half as thick, if not less, so would mean the tiles would look odd with the step down to the architrave. I suppose I could buy different thicker architrave.
I just think it may look better without the architrave there at all.
Any further opinions?
Thanks,
Daz
you can but dont use addy on the wooden lining
bring the tiles over the lining about 5mm to cover the joint and Silicon
id do as doug says the arks help to strengthen door jamb wich can move a lot with door opening and shutting ect
the architrave is only a decorative strip to cover the movement joint between wood and plaster, its not structural and doesnt hold the lining, if you have a loose lining the architrave will pull off
so you can take arks off and jamb wont move at all (try it) they make a difference just my opinion
thats right, the lining has to be rock solid as it has a door swinging in it and if theres movement it will worsen with the door continously closing into the jamb
arcitrave is only pinned on and will pull off a loose lining
and yes I have tried it, loose linings are a common problem that you come across when retro fitting doors, the first signs being a crack in the paint where the architrave meets the lining
ive fitted thousandss of linings on sitework and hung doors into them, the architrave is fitted last in case theres movement that needs dealing with, the architrave is a decorative cover mould and has no structural use in the door frame
if your finding movement when removing architrave then you need to refix your lining
Ive done a few with the arc removed , just have the trav finish in the same position as the arc, make sure u give the trav a slight bevel to finish.
I recon it looks great , very modern and clean.
Trev
DazJWood,
Martyn Leeds,
DazJWood,
Martyn Leeds,
