Discuss Tiling An Uneven Shape Room in the DIY Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hi, any tips on how you would tile a room that's not a good shape. I'm laying out tiles but finding the end of the room is causing a huge gap as the walls are not straight. Should I just follow the wall line? I don't see what else I could do. What's the best course of action?
WetSaw
Start with a centre line and work out to the walls, either with the grout line on the centre line or the middle of a tile.
Dumbo
Don't go a whole tile off the end wall . If you follow the centre line you will have to cut tiles at either end . No room is perfectly square
If that's a true representation of the room.
Find centre point at each end, strike a line between the two marks at either end.
Then as pdc says, start on or over the line, and as jcr says, don't just go full tile from one end.
Apply the same principle as above, on the other axis too. It will look perfectly set out.
Dan
Admin
To be honest that shape is as good as a room gets. Tiling one that's more of a triangle is the usual kinda setup. Then you're stuck working out which wall(s) are the most prominent or lead to other rooms etc to judge your degree off center when you've struck your lines etc.
It's coming together...
Reply to Tiling An Uneven Shape Room in the DIY Tiling Forum area at TilersForums.com
Lowpaul22
