Tilers Forums Hall of Shame....
Just read through this thread and seen some proper horrors. Saw something like this a couple of times;
What is the correct way to do this sort of cut? would you go to the trouble of getting the system drained, removing the rad valve and drilling the tile?
Sometime this is unavoidable. But, in the picture you have there perhaps some biege Silicon for the cut marks instead of grout would of looked a bit better.
Yes, if you want it doing correctly.
If that's not possible I normally drill a hole where the rad stalk comes out of the floor, and then from the wall side of the tile I would do 2 cuts on the wet cutter in a V shape towards the hole. Then I would fix the tile in place and then slide the V shape cut out towards the pipe which closes the gap left by the cut of the wet cutter. Possibly fill any little nicks with same colour silicon.
Sorting out a shower cubicle at the mo, it's been leaking. It's a catalogue of errors but my favourite part is the tray. The opening is 90x80cm and the tray that had been used was 70x70, the area around the edge had a little shelf on it, not a problem I hear you say, well here's what I found when I started taking it apart
Two courses of bricks, not stuck by the way just placed in around the edge, covered with about an inch of skim, then the tiled shelf on top! Some how this lasted 10 years before it leaked, mind you, there were several tiles siliconed to the wall, I'd guess that a dozen tubes of Silicon had been used.
Sent via Tapatalk for iPad
I need to get me one of those big square cutters for cutting wastes into the floor. :mad2: Tray's well supported on that corner then?
Massive hole Ali, I built a new frame out of 4x2 to put the new one on, screwed the frame straight to the joists.
Sent via Tapatalk for iPhone 5
It's shocking some of the things we find eh? That's a chunky stone tray as well. i think the low profile ones weigh in at around 25kg for a 760. That's gotta be about 35Kg+ sat there.
Ripping out a newly tiled bathroom which is only a month old. Carpenter had a unique fixing method!
Thats the Teflon version, non stick:lol:
Why are having to rip it off Geoff after only a month...
Its becoming a regular monthly discovery. Builders, plasterers and plumbers who say they do the whole job but...well, you know the rest.
Today's gem is an 800 quad held in place by 1 screw only, no Silicon in the base of the wall plates and about 2 tubes worth under the front bar. Oh, and a lovely surprise water feature in the dining room when they used it for the first time. They only moved in on saturday.
DHTiling,
bcd-87,
DHTiling,
bcd-87,
