Discuss Tile size for wall and floor ? in the UK Tiling Forum area at TilersForums.com.
I'm about to turn the bathroom into a wetroom and was wondering about tile sizes.
The room's about 3.5m square and I'm using Trav tiles, the mrs likes some 305 x 457mm tiles and I was wondering if they would look ok on the walls and floor and what config would look best.
If this is not advisable any alternatives would be much appreciated.
Also I was going to use a small pebble mosaic in the shower area, is this ok ?
Thanks in advance for your advice.
Os
Thx for the mosaic advice whitebeam, what are the problems with the pebble mosaic's ? (wife really likes them !!)
Also would using the same 305 x 457mm Trav tiles on the floor and walls be ok (it's taken ages to source a walnut travertine that we like)
Would you set the wall tiles landscape and how would the floor tiles go in relation to the wall ones.
Thx for the advice
Os
Thx for responses, big question still remains unanswered though, is it ok to use the same size tile on both the walls and floor (305 x 457mm).
If so, what might look nice regarding arrangement, ie. landscape on walls and line grout lines up through floor ??
Any advice would be greatfully received as I'm needing to order the tiles and if it's ok to have same size on floor and walls I'll use the same tile.
If anyone thinks this will look odd, what alternative sizes would work ?
Ta
Os
Reply to Tile size for wall and floor ? in the UK Tiling Forum area at TilersForums.com
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm...
