Waluigi
Bloody mitres. Two windows to go.
Discuss Thin porcelain suppliers in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Is there a particular resin that should be used for the mitres that someone could recommend?
I did a quick search but couldn’t find anything.
Bless you!Akemi
I like Tenax with coloured dyes for adjusting and tweaking colours, from Stonetools.com
I think Marc uses a different brand?
You may also consider Schluter’s answer to it AndyThanks. Sounds complicated.
What about these little tubs of grout, like Kerapoxy, easy poxy etc?
I take it they’re no good?!
I’m just keen to get something in the joint to give it some protectction although standard grout might be going in after all
Good shout Lee.You may also consider Schluter’s answer to it Andy
Schlüter®-FINEC | Function | Schlüter-Systems - http://www.schluter.co.uk/schlueter-finec.aspx
Reply to Thin porcelain suppliers in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
