Tanking law..
So good or bad then..?..
i think that sounds fairly good,but to me you have to stop the water getting in in the first place,i dont have a solution to that but i do believe that in the uk much of what is now available is more about revenue than the real solution
I just think that something needs to change.....how far this change goes then that will need a lot of work.....we are seeing to many failures of installations in bathrooms etc and peeps claiming on house policies for damaged ceilings/walls due to minor water leaks/penetration...from up-stairs.....
keep the suggestions coming please...they are great...:thumbsup:
The main problem is, as Wetdec said on the phone to me when I spoke to him about wetrooms, is that we have been demanding more flow rate from our showers.
20 years ago we would be lucky to get 2 litres a minute out of a shower. A few weeks ago I fitted 2 shower panels, each of which deliver 6 litres a minute, and that is relitively low these days.
So we're now getting up to 4 times the volume of water chucked at us when we're in the shower, no wonder things are getting desparate.
the problem what is now called tanking in a shower or bath area probably wouldnt prevent this,new builds for a start move or shrink far too much,also floors upstairs are tiled far too early in new builds imo,without the correct precautions but this should not be a tiler responsibility.
I find it harder to convince plumbers than a customer, I have seen tilers of 30 years plus have leaks which were that bad they travelled to the neighbours house and were solid brickwork which I had to repair the plasterwork, Were not talking just a spot it was serious damage thru the wall over a time:mad2:
Then what solution do you think we could have to this..?
Maybe a set time allowing for shrinkage should be enforced in new builds....
anybody else got any ideas on this theory..?..
well at the minute the drying out time is good coz nobody is buying them:grin:
Tanking law..
DHTiling,
DHTiling,
