Discuss Sub floor and UFH for upstairs bathroom in the Canada Tile Advice area at TilersForums.com.
Raccus
98
uk
Porcelain floor tiles to go down. Existing floor is floorboards on joists.
Was going to put 18mil wbp ply. But seems 6mm No More Ply is a better option (please correct if im wrong). Also seen premat mentioned. Much the same, or is one better than other.
Then because of the heating, i wanted to put insulation down first. Was thinking of marmox boards. But if they have those washer fixings, the fixings dont go totally flush do they? If adhesiving over top, its not too much of an issue, but if im to put NMP board on top, Im not convinced it will go down flat over these with no voids.
Alternatively, if using thicker marmox, maybe 12 or 20mm, is that enough to tile straight onto and so not needing the NMP?
Reply to Sub floor and UFH for upstairs bathroom in the Canada Tile Advice area at TilersForums.com
hello Folks, its a tiny area. 1.8 m2. Joists are solid 3 inch wide. Area is upstairs close to...
Hello all, After years of abuse, the bathroom needed an overhaul from top to bottom. Out...
Hi all. I came across this forum searching for info so my first post. I'm renovating 1890's...
Hi all, I’ve got an old Victoria house with 20mm first floor floorboards. They’re in quite good...
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
