Currently reading:
Self levelling over wet ufh system
Discuss Self levelling over wet ufh system in the Canada Tile Advice area at TilersForums.com.
Hi guys, the job, 140m2 of Mapei renovation screed over profix 15mm ufh system. It was to big for me to lay by hand so got a firm in to pump it. They have done a top job getting spot on flat but after inspecting it 2 and half days after it was laid I found pretty much every where it had the milky soft residue on top, looks like too much water in the mix. What can I do from here to make it tileable?
Cheers
Time's Ran Out
It takes a considerable amount of excess water to really weaken the end result.
More often it's salts and fibre rising to the top.
Not ideal, but no panic (usually).
Call mapei to put your mind at ease though.
But that's the issue - it may not be just sand it ...... etc. The Op will not know how much water was used, so the strength of the screed could be compromised. From the picture it looks like a fairly thick layer of soft surface material to receive attention. The firm who pumped it should be responsible for the correct mix and to provide a finished surface in line with Mapei product specifications.
Thanks for all replies guys. @timeless john os right , the layer that is milky and soft looks to be at least a few mm thick. The leveller was laid at 20mm thick on top of the profix , like an interlocking plastic base that the pipes sit in. Mainly the reason I didn't do by hand was because of this. I thought about sanding it but I'm worried it's just gonna be soft quite the way down, prob only got a few mm before we get to the pipe?
Will ring Mapei to make sure .
Id get the heating on goz , let them pipes expand and contract a bit and see what the leveler does .
This is no way aimed at you goz, but a lad and a tradesman would of done it essy really . Its not as hard (as in capability rather than graft) as you think
I have laid 100m in a few hours on a old screed before using pin leveller and spike roller and spike shoes, really enjoy it. A combination of this ufh system and lack of time and inclination on my part meant I passed it over to another flooring contractor. Plumber is there on Monday, will see if we can fire it up
Update, flooring contractor contacted Mapei and had a good chat with their head guy. They ran through the whole procedure, established the correct amount of water was in the mix, 4.2 litres , in fact that's less than I do! It was confirmed a slump test was carried out on the first batch mixed which confirmed it was not too watery or too dry. Ran through everything and it was said the contractor is very thorough in what he does. The Mapei guy asked if there were any kinks in the hoses at any point, a job up in Bradford had the same problem. Turns out there may have been kinks at points , causing the fibres to gather at the kink then spit out intermittently causing the fibrous finish in parts of the floor. It was said that a light brush to remove the top should release any moisture left in the slc which the contractor has done. It was also said the strength of the leveller has not been compromised.
Thank god for that!
Reply to Self levelling over wet ufh system in the Canada Tile Advice area at TilersForums.com
