Sand And Cement As Adhesive?
assegayer
Hi guys just a quick question, are you able to use sand and cement as a tile adhesive instead of the modern day 'tile adhesive'..because basically i have been to many countries where they use sand and cement in installing tiles and they seem to last donkeys years with no cracking or any problems i think they use the sand a a decoupling membrane which is certainly cheaper then ditra, but anyway i was just wondering how they do it exactly?
Here we go, run for cover!
you cant use sand and cement as adhesive just a bonding layer you use neat cement mixed with water to make the adhesive add sbr if fixing porcalain
how come they seem to put a layer of sand down then mortar on top then they fix the tiles to that?
The quick answer to your initial question is "yes".
The next thing is to say - unless you have a lot of experience and know how to do this - just don't.
Modern tile adhesives are there for 2 main reasons:
1 - Modern tiles are different - especially porcelain won't bond with virgin cement.
2 - The old skills are almost forgotten (thanks in big part to modern adhesives) so new adhesives make it easier.
thats a real shame to be honest because it seems them sort of installations are the most solid from a non professional tilers view that is. just wondered thats all as its interesting that they seemed to know that the sand will prevent cracking where as now they try to convince you that you must use matting in almost most installations
assegayer,
bansko,
assegayer,
bansko,
