Recommended thickness for 600mm x 400mm travertine tiles for outdoor use
the size of the notches on your trowel determines the thickness of your adhesive bed:thumbsup:
Because the body of travertine is quite holed , even a top quality trav has these but in smaller size compared to lower grade , these can retain water and in the winter months these pockets of water freeze , this then expands and can crack thinner stone.
You can buy 38mm trav which is specifically for exterior use.
With it being a thicker material it is less likely to succumb to such stresses.
Hope that helps.
Hope that helps.
isn't it too cold this time of year for exterior laying dave?
As you're usually razor Sharp Dave I thought you'd nave picked up on that lol, it was early in the morning though 🙂
tapatalk on my HTC
roligan,
doug boardley,
roligan,
doug boardley,
