problems sealing slate!!!!!
so do I and i would use a block bush with stainstop quiet often any way we are taking over this poor man,s thread
the best remedy would be to re seal and buff as you go, resealing will soften what you've already done and get the brush strokes out.
Impregnators you buff off and topical sealers you leave to dry... what is the one you used... was it designed to leave a wet look..? or matt finish..?
Hi mike. It's definitley not a case of grout/cement residue. The floor was clean and ready for sealer. Any ideas for removing the sealer so I can start again??
Hi Ruairi, sorry, no idea how you'd remove the sealer so you can re-seal. I think you should phone the Technical Dept of the manufacturer and see what they recommend, and maybe email them a photo or two in advance if you have some.
It's a mystery why they looked fine when sealed before grouting, then after grouting there's brush marks visible???
Good luck, hope you get it sorted out, must be frustrating to do a really nice job that the customer is happy with, then get a phone call the next day saying that a problem has developed. :mad2:
Thanks everyone for your replies, I'm going to ring the larsen rep this morning and see what they say.
I'll keep you posted.
Ruairi Mac.
Hi Dave just seeing your post. What is a topical sealer? haven't heard that term before. the one I used was Larsen tile, slate and floor sealer.
Think I'll try Doug's suggestion i.e. reseal and buff.
Ruairi Mac.
A topical sealer is a surface coating similar in some ways to a varnish. I believe the Larson product you used is one of these types of sealers, in this case a water based acrylic.
Always willing to be proved wrong but i would not expect the reseal and buff route to work other than possibly by several coat's to cover up the brush marks you described - Acrylics, once cured will not soften with additional coats
I have used LTP's Grimex previously to remove their Ironwax sealants(another acrylic sealer), might be worth a try
To get rid of sealer you applied use ltp grimex that will remove the sealer then re apply
But only use a paint pad and that puts it on nice and evenly
Hi guys.
Glad to say i eventually got this issue sorted.
I asked a local tiler who has a lot more experience than me to come and take a look at it with me. He took one look at it and was able to name the sealer i had used with out me telling him.
His solution was to use cellulose thinners to remove sealer, (I had my doubts but it worked a treat) it took a bit of time to do but brought the slate back to how it was before the fiasco. I then resealed with Lithofin slate sealer and i have to say its a much superior product. It looked very, very glossy when applied but dried out with a nice finish.
Customer was delighted with the end result, it took a few extra hours labour and a few extra quid out of my own pocket but sure it's all about keeping the customer happy!!!!!
Thanks to everyone who replied, it was much appreciated. I have a few photos and i'll get them up when i get a bit more time.
Thanks again
Ruairi
ruairi mac,
ruairi mac,
ruairi mac,
ruairi mac,
