Priming of floorboards before fixing cement boards?
mmmadman
Hi all
I'm using Topps Trade Rapid-Set Flexible adhesive to secure 6mm Hardy cement boards onto floorboards, do I need to prime the floorboards with anything?
Many thanks
you dont need to prime floorboards as the adh under cementsheet is only to fill voides so cementsheet is flat and sound screws hold it in place recomend you stagger c/s
Thanks for the quick reply, what type of screws do u recommend as the Hardy ones are to long @ 28mm. I got some external use screws from B&Q....!
best bet to go with the recomended ones or ones nearly identical external grade is better check around there are shorter ones
I like to overlay t&g with ply 9mm in small, deflection free areas screwed at 6" centres, then glue and screw Hardie 6mm (or the like) cement board over this. I know it might not be exactly to the book, but I also know it works.:thumbsup: I am now ready to receive the back lash. ( I always use Mapei Keraquick with latex plus) never had a problem:smilewinkgrin: I would like to hear anyones comments on this method.:yikes:
In theory Phil, it is to spec .. 15mm over board but with double layer adhesive.. so OTT for some..
do you mean the old style floorboards Phil, as opposed to t&g chipboard flooring?
mmmadman,
martifee,
mmmadman,
martifee,
