Points on Travertine wall tiles
marsaday1971
Hello
What size trowel do i use to lay travertine 12mm (40x40) on the walls. I was going to use 3mm. I also have a 6mm trowel if that is not big enough. I am using a powdered white adhesive.
I understand the area to be tiled shouldnt be plastered, which i have not, but the area where the tile meets the plaster above has a 10cm overlap. So i will be doing 4 rows high of 40x40 tiles and the top row will adhere to painted plaster by 10cm. Do i need to use my stanley knife and scratch into this plastered area to give it a better key ?
IMG_0007.JPGBit more reading and it says 6mm is good. I have done my top bathroom and all is good up there, just cant remember what trowel depth i used. Think it was 6mm, hence i am checking on here.
Any comments on tiling over a plastered area by a small margin. The rest will be onto cement board.
Also i am going to be using 3 tiles (40x40) as my splash back for the sink area (bowl on a cabinet) and this is painted plasterboard. Surley these 3 tiles will adhere all right to this area without any problems. Hardley get wet and weight will be low.
Also do you thin 3mm spacing is better than 2mm on 40x40 tiles.
40mm sqs .. ah explains the 3mm or 6mm , 40x40 here normally means 40cm x 40cm :lol:
Ok thanks for that. I am inclined to use 8mm.
Sorry meant 400x400 tiles.
I have the rear of the bath where i origionally thought i would just do one course of 2 x 400mm tiles, but i think i will make it up to be the same height as the rest of the tiling so it will be 4 courses of 2 tiles. The only prob here is that this area has been plastered and painted.
I understand this type of wall doesnt like a lot of weight so what do you think if i go for adding 8 tiles here instead of the planned 2. Is it a no no. I can stick with the 2 tiles if so.
Also do you thin a 3mm grout gap would look ok with these tiles. I have 2mm spacers, but i think 3mm may look better.
You'd be taking a risk, weight wise, with just plaster; but painted too? Not a good idea! A travertine tile on the head could potentially kill whoever it falls on, or at the least, seriously hurt!
Visually, I'd prefer 2mm grout lines. 😉
marsaday1971,
marsaday1971,
marsaday1971,
marsaday1971,
