dick turpin
Hi all, I have a bathroom floor to lay in opus ramano, 9 mtrs. Whats the best way to set out and where in the room would you start laying??? cheers
Discuss opus ramano. in the UK Tiling Forum area at TilersForums.com.
You can see from this floor that there is a grout joint somewhere in the floor every 6 inches (I think this is the size of the smallest tile).So I set out the room using a 12" tile,marked in the centre.
You have to laugh, just been to see the job and its 4.5 m2 not 9 and there are 4 tiles sizes not 3......customer is always right......not. I did lay the tiles out to check them and found, as captian slow said that the pattern does indeed dictate the grout size, one concern is that this leaves a realy tight grout line 2mm at the most, is this right??? any thoughts chaps and chapesess. I did get the job will do it this weekend.
I'd try to get a bigger joint if you can mate. 2mm is a bit tight for floors to be honest. Though if the tile isn't allowing you, and you're 100% on that, then you'll have to go with that.
Reply to opus ramano. in the UK Tiling Forum area at TilersForums.com
