DHTiling
As long as the floor is flat it will be fine , it does not have to bubble level if the floor is out that much , just get it flat to eliminate lippage as you say. when cross bonding.
Discuss opus pattern problem in the Canada Tile Advice area at TilersForums.com.
So in all likelyhood a s/c screed will crack up but a gypsol screed will be ok with said thickness any differantway i should approach tiling a gypsol screed appose to a stabndard s/c thanks
Reply to opus pattern problem in the Canada Tile Advice area at TilersForums.com
