non slip tiles
Matty A
other than the purpose made non slip tiles are there any others that offer good non slip factors ie porcelein or similar
I use a porcelain tile regularly that has a sort of slate effect texture to it and is pretty much non slip, made my monoceram and comes in many shades. you can also buy a non slip solution to roller on to tiles but is expensive.
nothings non slip,we used a tile 144cms wide by 100cms in lengh with a bal non slip sealant,you can wait for it to dry ,
crack on ar kid
I'll find out for you matty, one of the tile shops i use in glasgow, cosmos ceramics has one of the largest show rooms in uk and stocks everthing! I'll be back down there this week, i used this gear on a cosmetic dentists surgery floor where the tile was a black shiny item with silver flecks through it but really smooth. he was worried that clients would slip on it! Ok if they knocked their teeth out though:shades_smile:
slightly spammy for my first post but try [DLMURL="http://www.grip-on.co.uk"]Anti Slip Treatments Grip On International Ltd[/DLMURL]
:angel_smile:
There's the likes of quarry tiles and slates and things that are rough enough to be classed as anti-slip (which is the phrase I think we should use rather than non-slip). Then there are your glazed anti-slips, these should be denoted as anti-slip in the tile store but if not grap an assitant and ask them and they should be able to sort you out.
I'd generally stear clear of getting a slippy tile and then using a liquid to make it non slippy personally. If the customer wants that, then tile the floor and give them the bottle of stuff.
Hope this helps.
non slip tiles
Matty A,
Dan,
Matty A,
Dan,
