Discuss Next Project! in the DIY Tiling Forum area at TilersForums.com.
423
N. Ireland
I have a couple of local tile shops but they don't sell mapei etc.
I get confused very easily with acrylic primers/ SBR/ diff adhesives etc
Local shops sell Larson and Dunlop adhesives and arc highbuild self level
423
N. Ireland
423
N. Ireland
I got this at the weekend from the local shop to build up a floor where the fireplace hearth was removed and the floor was low.
This was a mix with water only, the floor was going to be laminated flooring so wasn't as worried tbh
Would it be suitable for the porch before tiling?
Time's Ran Out
If the floor was good enough for vinyl why are you thinking of a self levelling compound?
423
N. Ireland
Too try and kill the vinyl adhesive that I can't remove easily. From past experience I had a nitemare with it and was hoping self level would be an easy solution to that
L
LM
Any TWO part leveller will do the job so long as you don't exceed the recommend depth
423
N. Ireland
OK so removed as much glue as poss, SBR n self level with local suppliers two part lebveller.
Then SBR again?
Do I need a flexible adhesive ?
L
LM
You shouldn't need to prime again and for all the difference in cost for the size of this job you'd be better to get flexible adhesive
E
ExplodingPudding
Vinyl adhesive can cause problems for the tile adhesives that I sell personally so can't comment as to the OP's choice. But from hearsay, vinyl can be a nightmare once it's removed. If you ever get the chance, ring BAL or Maipei and they can explain all the in's and out's a lot better.
Reply to Next Project! in the DIY Tiling Forum area at TilersForums.com
