Currently reading:
New tiler buying a wet saw. Budget!!
Discuss New tiler buying a wet saw. Budget!! in the UK Tiling Forum area at TilersForums.com.
DHTiling
Try this one from tradetiler........
Plasplugs Mastertiler DWW180
  • Cast alloy deck (with lifetime warantee)
  • 180 mm diameter (22.2mm bore) wheel included
  • 27 mm cut depth
  • Height adjustable wheel guard
  • Flip-up guide plate for 45° mitres
  • Unique Hi-Torque 650 watt motor
  • Carry handle
  • Unique water re-circulation system
  • Cutting guide - use left or right
  • Click-grip calliper locks
weight 16 Kg inc packaging
TradeTiler.Ltd Wet Saws
The Dewalt is a big machine and good for slate, marble etc.
it takes up a lot of room in your van but I think it is good
value for money because it has a sliding table and it can
be use as a chop saw whitch is good for taking complete
holes out out of tiles eg elec sockets if using large tiles
in kitchens.
where as a lot of the big wet cutters can only run and
not chop.
hope to be of help
medlar
heres a cheap little wet cutter,never used 1 but my mate has had his (although this is the latest version) for about 3 years and found no problems with it
Erbauer ERB180C Tile Cutter Chrome Top 230V
http://www.NoLinksToThis/sfd/i/brandimages/Erbauer.gif http://www.NoLinksToThis/sfd/i/spacer.gif​
Convenient-sized, chromium-coated table and waterproof switch. Table is tiltable for various applications.
  • Induction Motor
  • Max. Cut Depth 35mm
  • Diamond Blade
  • Work-Piece Clamp
  • Blade Brake
  • Parallel Fence
  • Mitre Guide
  • Steel Table
ERB180C, parallel guide, 45° mitre gauge, water tank, blade.
johnnyp
Hello All,
I had a small 'plasplug' wet cutter and my real moan was measurements were poor,also adjustment bar clips were weak. I replaced it due to frustration!!!!
Bought a 'Rexon' TC1150AL , 720watt good power and clean cut. I know it's a cheapy but VERY functional. Good extention table, to both sides, great adjust scale /bar.
Had it couple of years ,done a fair few jobs with it.
Screwfix do them for about£56 - 58 , if you break it Screwfix change it!! can't be TOO bad!
GOOD LUCK
Johnnyp
Reply to New tiler buying a wet saw. Budget!! in the UK Tiling Forum area at TilersForums.com
  • Sticky
