New member here...question on adhesive for matting.
Bob2
Hi everyone,
I have been following this forum for about 14 years now and have always found answers to my questions...so thanks for all the previous info you have all provided me. Excellent forum!
I cannot however find an answer to this next question...
...I will be doing an 18sqm floor in glazed porcelain tiles, 10mm thick, 600x300mm in a brick bond pattern. Grout will be grey. The client, (a friends dad), has extended his conservatory and the new floor is a concrete screed which has been brought level with the existing ceramic tiles, and there is the obvious join between the two substrates. The tiles are solid with no movement. I did ask him to lift them and get the builder to self level the whole floor, but he was adamant he wanted them left alone and I tile over them, so I have to deal with what i've got.
I am going to put a Durabase Ci matting over the whole floor, but the data sheet says to make sure I use an S2 adhesive. Now my tiling is good, but my speed is not and all I can find is rapid setting S2 adhesives. I usually use Mapei. Can anyone tell me a good standard setting S2 adhesive to use with this matting please? I will be very grateful for your replies.
You should also install a movement joint between the new and old floors. They will expand and contract independently.
Always thought that S2 adhesives impedes the function of cavity mattings like Durabase or Ditra. Looked at the instructions and it actually says C2 adhesive. Most people will use rapid or slow set C2 or C2S1. Lots of good brands about, Tilemaster, Ultra, Mapei.... the list is endless. Shop around locally, see what's available then come back to us and we can give you some further opinions.
Hi Paul, thanks for reply. I was going to use Mapei Keraflex as it's one I'm familiar with, however, didn't think it was suitable for the matting? As regards the movement joint...the customer would rather not have one as he says it will look out of place and 'industrial' in his conservatory floor.
Rocatex do a standard set s2. You can't use s2 on top of durabase. The expansion joint doesn't have to be mechanical. It can just be a grout joint with colour matched Silicon in it. You'll never know it was there
Thanks mate...I hadn't thought of the Silicon idea...I wasnt aware of it. I've obviously read the durabase data wrong then if an S2 can't be used. Will read it again tonight.
It'll be c2 as Paul said mate
Yeah..thanks mate....Mapei Keraflex should be fine then. If the customer wants a brick bond pattern over the floor...how will I put a movement joint of Silicon in over where the substrates meet? Or is that just not feasible with that pattern?
it's either cut them through or have them the other way on the transition
Bob2,
Bob2,
Bob2,
Bob2,
