New member Artist looking for advice on tiles forum ;)
I can tell you for sure you can’t glaze and fire those, so your looking for a resin, there are a few resin floor coverings around perhaps they might withstand the heat
I have a sample unit of some Resincoat clear floor epoxy that I am about to test on some Grade 1 floor tiles, to see if it gives them better wear resistance without losing the tile any definition from the tile design. Once I've done what I need to do with it, I'd be more than happy to stuck a cuppa on it to see what happens. Or if I have enough will do a separate test tile. I have the datasheet but there is no info on final heat resistance. It's industrial grade, can be used on factory floors so you'd think it'd be pretty indestructible. Will keep you posted.
Hi, I`m a new member😉 my art project research bring me to his forum. I need advice about tiles.....
So I wanted to make small projects on ceramic tiles for coasters purpose using my acrylic paints and inks . Problem showed up when I tried to find good product which can seal them. I tried Ultra Cast resin which supposed to hold 95 C. After leaving hot cup on it it left the marks in resin;/ .
I would like to buy resin alternative ? I need something checked that won`t ruin more of my art pieces;/ Could someone recommend me product for coating tails:
-permanent, water resistant
- Will be UV resistant
- Crystal clear gloos
- heat resistant- you can leave on it hot cup
-good scratch resistant
- if possible low odour
Project covered in resin:
damaged coaster- cup marks:
tile just with inks ready to coat with.....?.Help me to find what i should use please😉
Hello ,ive been looking for a course on the resin you do ,did you learn yourself or a course,i think tiles would be a good surface ,no one in my area knows of anyone who teaches this and i live in a very artarea ,lots of artists and galleries ,thanks ray
Elwira,
Unused Account 1,
Elwira,
Unused Account 1,
