My builder says epoxy grout too "inflexible"?!
Another thing with shower mould . If you have a shower cubicle and you have extractor you still won't get any air movement in cubicle so I think it is a good idea to leave cubicle door open if you have sliding doors to promote air movement in cubicle .
Ventilation, or "lack" of it is the biggest problem with most grouts & silicons. Although a good grout & silicon have anti fungal properties (microban) you just cannot beat drying everything out after using showers etc.
Extractors and window open does the world of good
People say he might be trying to wriggle out of using epoxy, well he might be doing you a favour. If he's never used epoxy before then don't expect the quality job you want, you will regret it. I've been tiling for over 40 years and I personally would try and talk the client out of using epoxy especially if all the fittings are in (not sure if they are). We use epoxy on large commercial jobs i.e. Swimming pools mainly and have 2 lads who are very good and quick but it takes years of experience to get to that standard, it's also been considered a health hazard and most tilers will refuse point blank to use it. I know we're only talking a bathroom here but be careful you can have a perfectly good tiling job ruined by using epoxy resin grout. There are many grouts available now with all these additives that are compatible with your requirements, but like has been mentioned earlier ventilation and a little maintenance is required.
If he sticks to the instructions to the letter, uses the right gear, and perhaps even checks the forum out or some YouTube videos, he should be fine.
Test him & it on a small area behind the door or something first. So if it goes wrong or he hates it, it's not an eyesore.
in my opinion the easiest remains kerakoll BIO fugalite.
it takes almost half a time, compared to mapei, bisazza and normal fugalite
But in the UK it's all moaning about price. "Too expensive"!
As a result, Kerakoll is very difficult to buy.
Tardigrade,
LJD,
Tardigrade,
LJD,
