Discuss My biggest tiling job yet in the Canada Tile Advice area at TilersForums.com.
So you sound like you know what you're talking about tomorrow, basically if it is anhydride stick an antifracture mat/ decoupler down with an anhydride specific adhesive like anhyfix.
It will need a prime coat first.
Stick your decoupler/antifracture mat down and then you can use regular cement based adhesives on top.
If you don't use an antifracture, you'll have to use the anhyfix to stick the floor, but general opinion of most is that using an antifracture affords so many benefits it's worth it, even if it's not a heated screed.
If it's sand and cement, which sounds doubtful, tile in an conventional way, still using expansion joints. Which for a best result should be actually cut into the screed not just in the tiling.
Oh ok some heating, best stick to the 40m2
Well that gives you a good excuse to push for the antifracture/decoupler too.
You can use a cold joint as an expansion (mastic) but not perfect.
That's basic info but should help you thro the first conversations.
So rest is up to you. :)
For now anyway.
John Benton
Points
1,138
Leeds
Just noticed that you are in Navenby Carl, been through there loads of times, was down in Metheringham all weekend just got home
Carl Haynes
For now anyway.
3 fall. Thank you so much for your help and advice. Much appreciated. Cheers mate.
John Benton
Points
1,138
Leeds
Haha great mince pies, my wife used to go there when she lived down there
Well I hope you read this in the morning.
Sorry been a tough weekend.
If it turns out to be anhydride it WILL need sanding. There will be a laitence covering on top which needs to be removed.
Using a 60# carborundum pad and floor polisher. Swept vacuumed and primed.
And the heating system needs to be have commissioned i.e. Put through a complete heating cycle in the correct manor.
Sorry it's an afterthought, but very important nonetheless.
Good luck.
Reply to My biggest tiling job yet in the Canada Tile Advice area at TilersForums.com
