Currently reading:
Mosaics...... fix & grout ?
Discuss Mosaics...... fix & grout ? in the UK Tiling Forum area at TilersForums.com.
Jimmy
I have been asked to tile a spashback in a very large kitchen with 20 x 20 ceramic mosaics. Due to the size I was considering using fix and grout, normaly I would avoid the stuff with a passion :thumbsdown: . Under the circumstances I am warming to the idea. If pushed could any one recomend any ?
I also looked at BAL mosaic fix , the product description states its "brilliant white" and wondered if I could use it as fix & grout or grout over the top not worrying that bits may show if its the same "brilliant white" as the grout.As anyone used it?
I would be very greatfull for any advice as I am sure it would save me a lot of swearing and tears.:smilewinkgrin:
R
Rob Z
Are any Laticrete products available in the UK? If so, then Laticrete 4237 Latex can be mixed with sanded grout to make a color-matched setting material. The beauty of this method is that any setting material that oozes up into the joints can be struck flush with the top of the grout line and left to cure. Then, the next day, the same grout can be mixed with Laticrete 1776 latex additive to make the grout to finish off any of the joints that weren't filled while setting the mosaics.
If Laticrete isn't available there, maybe there is another company's material that does the same thing?
http://www.laticrete.com/Portals/0/datasheets/lds2301.pdf
R
Rob Z
Dave, another good thing about that pooky is that it has a long open time on the substrate. It has something like 2-3X the normal moisture retention goodies in it and it won't dry out for a long time once it's troweled out.
One time I was setting mosaics on a mud bed (screed) and I got a phone call just as I finished troweling out about 9 square feet of material. I went outside and talked for about 10 minutes, and then remembered the material on the floor, I raced back in thinking for sure it would have gone off by then and I would have to chip it off ...but instead it was still as soft and tacky as when I troweled it out. :thumbsup:
Jimmy
:thumbsup:Thanks for all your quick replys. Just had a look at the mapei p10 online and think it could be just the job. Being adhesive and not paste, I could mix it up nice and stiff to minimise it pushing through the joints.
I already use the grout float trick on boarders but did not think of the paint brush trick, it makes so much sense i,ll not forget that one in a hurry.:hurray:
Thanks again everyone ,CHEERS:8:
Reply to Mosaics...... fix & grout ? in the UK Tiling Forum area at TilersForums.com
Hello, I'm just a home owner who doesn't have much experience with tiling but I'm looking for advice on fixing a few problems that a professional left me with. He of course has not responded to...
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
