Liquid Damp proofing Old Floor
Drifterjoe
Hi Guys,
Ripped up some tiles on an old floor today. Some of the tiles were came up very easily and there was a very slight damp feel.
It's obviously very minor rising damp as the tiles have been down 30 odd years.
I've looked at the mapei epoxy dpm but it's pricy and only need a very small amount as the affected area is small and the damp isn't that bad.
Any advice on a cheaper alternative that I can tile over? Whatever I use I'm going to SLC over the whole floor afterwards.
Cheers
Hi thanks for that.
Anyone know if this would be suitable?
Sika Waterproof Coating Grey 5kg - https://www.screwfix.com/p/sika-waterproof-coating-grey-5kg/83502?tc=HB9&ds_rl=1249484&ds_rl=1245250&gclid=CjwKCAiAmb7RBRATEiwA7kS8VEBJTzh0Vy4XhQLyltXAifY9B7hrn512VjPP0kf7kwGhcsZCbBsIXRoCSi4QAvD_BwE&gclsrc=aw.ds&dclid=CIGW1KmWhNgCFSki0wodbhMIRA
Sika waterproof coating. It's cement based so if I Primed it then SLC over the top would it be ok? I only need to treat about 1m2 of the floor.
Phone sika technical then when they tell you it's alright ( if they do ) get them to email you a method statement .
0B636C85-88BB-49C5-8891-E346B76B3C2E.jpeg I’ve used the Tilemaster dpm and it sets like rock. It’s not cheap tho, but do it once and do it right.
Cement based tanking systems such as sika , can be used in this situation. However if you are confident that rising damp is minor and won’t transfer or increase any, you could prime concrete with a couple of coats of SBR (moisture and salt resistant)
Coupled with a quality Slc, and tile adhesive - in such a small area, it should be fine.
If you do as above your levelling comp should be moisture tolerant . Something like arditex na or ultra level it 2. Some levellers will expand with moisture contact and fail .
Drifterjoe,
Bond,
Drifterjoe,
Bond,
