Leveling Compound Failed
Millington Deco
Has anyone seen self leveling compound fail? I've looked at a floor tiling job and the leveling compound laid 24 hrs ago is crumbling and dusty, it disintegrates when swept in places.
What is the cause of this and how can it be fixed?
Sounds like too much water when mixed.
If it's a concrete floor you could try a few coats of primer at 1 to 1.
Was it a 2 part levelling or just one that water was added to...as above if to much water added.
Over watering has created a weak mix , needs to be removed , no other way ...
Customer wants to avoid removing it as it's been laid on 20 m2 of underfloor heating wires and insulation boards. :tearsofjoy:
Sounds like the decision is made then!?
I wouldn't risk it if it's that crumbly, get it up & start again.
What SLC is it? What brand? What mixing quantities were used? Any photos?
Millington Deco,
Kyle Knowles,
Millington Deco,
Kyle Knowles,
