MTiler
Hi
Water leaks through paving slabs into the walls of a paddling pool and seeps out through the sand under the slabs which caused the old tiles to come loose along the top. The pointing has come loose and previously someone has tried using silicone to seal the paving and edging slabs but thats now loose. Will completely repointing/grouting everything properly do the trick? There are also Sealers you can get for paving. Theres no drainage system around the pool.
I dont particularly want to remove the edging slabs and re-lay the lot as it'll wreck the tiling we've just done, but it could be the case but I dont know much about paving (if anything). Perhaps I should get someone in who does.
Anyone else come across a similar job?
All this shouldve been sorted before any tiling took place but thats councils for you i suppose.
cheers
missT
cheers
missT
