Laying Wood Effect Porcelain - Advice and grout selection
Buckfast
Hi All
Getting a big job done on the kitchen come living room. Having wood effect porcelain planks installed. It is part of a renovation of my new house and the builder is looking after most of the work. He will have his tiler do the work, but just wanted to check in here with the experts to make sure all is done properly. (Im in Ireland by the way).
1. We are going for a 2mm joint, im told that anything else is not advisable. We dont want to go larger as I prefer the look of the narrow grout line.
2. We are going with a 33% overlap, as I have seen this recommended.
3. I need to source the best quality grout (the builder is getting the adhesive). Is Mapei Ultracolor plus a good choice?? ( I assume this is a flexible grout?)
4. Any advice on choosing a grout colour?
1. I'd also go for 2mm joint despite BS advising 3mm
2. I prefer random but if 1/3 bond suits that's up to you. Get the tiler to lay a few loose for you to see.
3. I'd use Ultracolor Plus.
4. I'd go for a grout colour close to or just darker than the tile colour.
A perimeter movement joint is essential and, if it's a big job, there might also need to have intermediate movement joints, depending on shape/size of floor(s).
Hi and welcome to the forum.
Where in Ireland are you?
We have Irelands finest tile contractor as a member.
To be honest, a random tile layout looks far superior to any regularly staggered design.
If a competent fitter undertakes your project he should be able to accommodate.
Ucp is a good grout, however not liked by all.
Personally I like a dark contrasting grout with planks so that it resembles a real timber floor.
420540BF-CC2F-403F-96B7-C482DA96B711.JPG 04A85D5E-5F7B-4112-B7E3-028E6B653879.JPG B5083D71-A808-40D1-BA7F-4160D6931130.JPG 7389FF82-90EB-474A-B855-50D56058BD2F.JPG
In your comment you say the builder is getting your adhesive. Is it a builder doing the tiling? or a tiler? Planks can be quite tricky and easy to get wrong. It could be good for you if you ask him if he's confident and competent to carry out the tiling. There are too many threads on here of bad installs. He may well be a great tiler.... just thought i would mention it.
Thanks both. I just thought about 1/3 as it has been recommended. For example, the Mapei website recommends it. I think random might be nicer too. Great looking work there in the photos. I am in County Meath, Rep of Ireland
I'm with Marc, random bond looks far superior for me. Mapei UCP I don't have any problems, used to do, but not any more. Watch out for bowed tiles though, check before laying, otherwise your builder/tiler could end up in a mess
thats the prob with planks....bowing ....ive laid some really good ones even 1.2 long but ive seen some shockers ..bananas
Buckfast,
emmettcraik,
Buckfast,
emmettcraik,
