Discuss large format tiles in the UK Tiling Forum area at TilersForums.com.
U
Unregistered
PJ
Can anyone help?
I am applying large format porcelain tiles to a wall using white powder adhesive. Can anyone tell me what size trowel I should be using to get a suitable bed thickness?
Dan
Admin
Staff member
Points
1,318
Staffordshire, UK
Re: PJ
You need a good thick layer, there are large format trowels available for this type of job. See tradetiler.com for a couple of options. As they are on the wall though you may get away with a thick-bed trowels that's usually used for floors.
Hope this isn't too late, I've been out of the office for a while. :)
Concept PHT
Re: PJ
You also need to make sure that the tiles are not too heavy for the wall. The standard is 20kg per m/s on plastered walls.
U
Unregistered
Re: PJ
stop the bus !, what size large format, what thickness & what is the wall made from ? You may not even be able to tile onto the surface with your tile !
Reply to large format tiles in the UK Tiling Forum area at TilersForums.com
