Kerakoll Fugalite Eco :)
This grout has been spec'd on my job next week and the only thing I cant find any info on is, how long after application do I wash off? The tiles are porcelain and there is a tumbled travertine mosaic border if that information helps. Thanks. @MissTiler
This was the tub we mosaiced - ready to be inserted into position,drilled and fitted around. Grout was taken off within 20 mins of squeegee on with white pad and their 'wash' . A great epoxy grout.
As soon as youve applied the tub clean it off. I didnt need to use white emulsifying pads. I was using the translucent grout with glitter, perhaps the coloured grouts might need white pads in the cleaning process.I just used a half decent sponge and sponge cloths. A capful of Wash goes in water to clean it. When its dry use the Soap to clean of any residue. I couldnt believe how easy it was to clean. I used it on these mirror mosaics and there wasnt any smudging after washing it down.
Still need to wear Nitrile gloves etc.with it.
Sorry just realised Ive already posted this pic 🙂
It's very coarse and very difficult to strike off smoothly which leaves quite a rough surface, which surely defeats the object of an epoxy if the dirt has somewhere to sit, it reminded me of bal wide joint when doing the walls, quite a task to keep it off the floor. As for the washing off, I washed it 4 times with their liquid in hot water and there's still a greasy residue that I can hopefully get off in the morning when it's set. The biggest issue is how long it takes to set, every wash just pulls a bit more out of the joint and smears the tile face, I used a new sponge for every wash and followed the instructions very carefully. And my final gripe is its 8 times the price of a cement based grout, now that's just outrageous.
amen.......
I confirm what he said bri.
fugalite is grainy, after last wash, it looks like sand.
(Could this be the reason, the ease in cleaning).
of fillgel bisazza finish, much finer. however, much harder to clean.
MTiler,
Simons70,
MTiler,
Simons70,
