Discuss How to avoid chipping porcelain tiles in the DIY Tiling Forum area at TilersForums.com.
Hi I'm currently trying to tile my Cloakroom - have purchased porcelain tiles and a wet saw (Vitrex Versatile Power Pro 750W with a Rubi CPC180 Pro Diamond Blade)...
I'm having difficulty cutting tiles without chipping them (generally/sometimes when i get to the end of a cut the tile fractures before the blade goes through it) any tips?
Thanks.
Tony_C
Go nice and slow, you may be pushing it through too hard/quick. Make sure there is plenty water in the cutter. The blade itself may need dressed.
For the fracture issue cut into the opposite side by 10/20mm and then flip it round and cut as normal. That should help stop it snapping off at an angle. If you have a score and snap cutter you can also score all the lines you need to wet cut also to help prevent it splintering off
Reply to How to avoid chipping porcelain tiles in the DIY Tiling Forum area at TilersForums.com
Teejay
