How to avoid chipping porcelain tiles
Hi I'm currently trying to tile my Cloakroom - have purchased porcelain tiles and a wet saw (Vitrex Versatile Power Pro 750W with a Rubi CPC180 Pro Diamond Blade)...
I'm having difficulty cutting tiles without chipping them (generally/sometimes when i get to the end of a cut the tile fractures before the blade goes through it) any tips?
Thanks.
Go nice and slow, you may be pushing it through too hard/quick. Make sure there is plenty water in the cutter. The blade itself may need dressed.
For the fracture issue cut into the opposite side by 10/20mm and then flip it round and cut as normal. That should help stop it snapping off at an angle. If you have a score and snap cutter you can also score all the lines you need to wet cut also to help prevent it splintering off
DIY Tiling Forum
TilingNewbie,
Tony_C,
TilingNewbie,
Tony_C,
