Discuss How long to wait before sealing new grout? in the UK Tiling Forum area at TilersForums.com.
P
plugger2
How long to wait before sealing new grout? Cementuous colour grout, 2mm joints, nothing unusual. Sealer is solvent based, rather than water based, if that makes a difference. Area is a kitchen backsplash, and so I would like to seal sooner rather than later to avoid any fatty/oily residue from cooking getting onto the grout first.
Surprisingly, manufacturer's data sheets have nothing to say on the necessary curing time before sealing for new grout (I looked at both the data sheet for the sealer, and also for the grout itself.) Any general guidance?
Dan
Admin
1,318
Staffordshire, UK
I'm guessing that the grout datasheet will quote a time you can put the room into full use (so shower in the shower area etc etc) so I'd guess that'd be the time to seal it.
Wait for a response from the lads though as I'm probably wrong there?!
P
plugger2
The only curing time mentioned in the data sheet for the grout itself was "wait 24 hours for cure before removing grout haze".
Dan
Admin
1,318
Staffordshire, UK
Hang on for the lads.
What you want to do make sure of is that all moisture from adhesive and grout has fully dried up, else you'll be sealing it in. Tiles can soak up moisture too, so you're waiting for those to dry out properly also.
AliGage
Subscribed
1,138
Peterborough, England
This is a really interesting question actually. I don't have a definative answer, nor am i certain with the answer i'm about to give:
I usually seal up my installs last thing. To ensure all dust and dirt has been removed and the room has been cleaned down.
Grout takes 24 hours to cure. Check data sheets and info of whatever grout you used to be sure. But, i think as a general rule of thumb 24 hours is correct. So i'd allow a minimum of 48 hours to be on the safe side.
I know it's not relevent in your case, but i would leave shower areas a lot longer. It's advisable not to use a shower for upto 2 weeks after grouting. So in this scenario i would seal 48 hours before the shower was ok to use.
Dan
Admin
1,318
Staffordshire, UK
Somebody must have the rock hard facts somewhere.
I'd go with Ali for now though. Seems more logical than mine. :lol:
DHTiling
Aerosol sealers like LTP's etc can be used about 20 mins after washing down the grout.... but IMO if the grout is wet then adding sealer will soften it some what... so let it firm and then use the aerosol but if using other types then seek advice from sealer manufacturer.
Quote from LTP aerosol sealer directions..
Newly grouted surfaces should be left to cure for 20-30
minutes and should be clean and free from dust before application
Full instructions here>> http://ltp-online.co.uk/images/tds-Grout_Tile_Protector_Aerosol.pdf
P
plugger2
Thanks all -- the HG product Bri found the product info for looks very similar in spec to what I'm using, so waiting 72 hours (more in humid condtions) it is!
Actually, it's already been 72 hours, so I'll get onto it today...
Reply to How long to wait before sealing new grout? in the UK Tiling Forum area at TilersForums.com
