Discuss How do you wrap tiles onto window sill? Just can’t seem to get the joints to line up perfectly? in the DIY Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Yeah if the wall tiles aren’t flat that will throw it out if and I think if you went straight bond it wouldn’t look right maybe get a tile big enough to make a window sill out of it just a thought but might look pretty good something that’s contrasts the white metrosYeh, it’s level and I didn’t keep the off cuts. There was a bit of a bow in the wall so I’ve took them off and straightened them up so hopefully that was the problem but I’ll have another try tomorrow. Thanks for the reply. Do you think it would look stupid with the sill tiled in straight bond if all else fails ?
[automerge]1579127210[/automerge]You sure you have followed the pattern correctly?
Have you got a pic of all the tiled wall?
[/QUO
Haven’t got a full pic but I’m pretty sure I followed the pattern correctly. They’re not miles out just millimetres but it doesn’t look good obviously. I’ll have another go tomorrow but I’ll lay them dry this time to save getting adhesive everywhereYou sure you have followed the pattern correctly?
That’s an idea. Thank youYeah if the wall tiles aren’t flat that will throw it out if and I think if you went straight bond it wouldn’t look right maybe get a tile big enough to make a window sill out of it just a thought but might look pretty good something that’s contrasts the white metros
[automerge]1579127356[/automerge]Yeah if the wall tiles aren’t flat that will throw it out if and I think if you went straight bond it wouldn’t look right maybe get a tile big enough to make a window sill out of it just a thought but might look pretty good something that’s contrasts the white metros
15/20mm black/grey porcelain would look pretty awesome aswell I like to put added details into tiling I do that with niches now I Use a different tile in the niche than the wall tiles[automerge]1579127356[/automerge]
Good idea that , maybe a bit of limestone
Reply to How do you wrap tiles onto window sill? Just can’t seem to get the joints to line up perfectly? in the DIY Tiling Forum area at TilersForums.com
