The square dose not have to be massive a standard roofing square will do and you would just place one side of the square on wall (A) the square will do the rest. I would go in to more detail but to be honest I have just had a look at your profile and think that if you have been tiling for 15 years and can’t work out how to use a square then there is not much point wasting my time trying to explain it.:mad2:
No it wont mate !!! lol !!!!....wall A is off square, If I put a a square on it, how do I ensure that I get it 90 degrees to the line I want to take across the room , so that I can copy the vertical line in the same position of the opposing wall .....because it's all running off ...get me ??
I've included a drawing as well here, maybe that will help :hurray:
Now then ....this seemed (to me) the most sensible way to do this, maybe somebody else knows better, I dunno, but that's why I'm asking guys :yes:
Ok, Wall A is very busy with lots of things you cant see in the photo ...there's a window, a fan , a switch, a sink and another vertical box in ....so to me, it makes sense that Wall A must dictate the best set out for the tiles, to get the most even result.
However, the Toilet front (C) and the back wall (D) are also off square in opposite directions .....which would look attrocious if I simply "centred the walls and took the tiles round the room on the horizontal like you normally would ! .....still with me ?
So, the only way to get the right result is to let wall A dictate the layout, make sure that the VERTICAL line matches on the opposing wall (B) ...then I know how much I need to straighten out in between, so that it looks right ......that's the thing that I don't know how to achieve, when everything is on the p*ss and theres nothing to get a square from - i.e a true 90 degree, to copy the line across the room
In the line picture, the red signifies the walls and the toilet front ....the blue is how I need to tile it, for it to look right .....so the vertical must line through on opposing walls or it looks different on both sides ....with me ?
